Not sure why or what happened, I was doing some cleaning on my computer(uninstalling games and cleaning up in general) and somehow the file went missing. I wasn't uninstalling anything related to 3ds and am confused about what happened. If someone can help me out, I really need a hand to figure out what is going.
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous,
It's not unheard of for anti-virus applications to run a false positive from time to time, or perhaps that .dll was somehow referenced by another program in windows and was removed when you uninstalled things.
You could try 2 things:
1) If you still have the Autodesk folder that the archives unpacked to at c:/Autodesk you will likely find the .dll in there.
2) You could try to do an installation repair and see if that helps. (Mostly redundant links but more is better than less.)
Please let me know if you continue to have problems. EDIT: I have attached the .dll as well.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
Best Regards,
Hello @Anonymous,
Just wanted to follow up. How is it going?
Best Regards,
Hello @Anonymous,
Best Regards,
Hello Alfred, I was having the same issue and I located the file where you said it would be. Now what?
thank you
thank you
Hello @Anonymous and welcome to the community,
You should just need to put it in the root installation directory of your Max program. For example: C:\Program Files\Autodesk\3ds Max 2018
Can you please try that for me? Thanks!
Best Regards,
Best Regards,
it dus not work becouse te prg is also mising ogsobjects-16.dll ???
maby you kan help
maby you kan help
