converting 3ds Max file without the application?
Very new to the community. I've purchased a model to use in a project that I'm work on. But the possed model I need is .max.Mobdro
I just need to bring the file into my scene Kodi in Keyshot, bluehost but .max in not accepted in Keyshot 5. I'm trying to convert the .max into .obj file.
I've tried loading 3ds Max, but could not successfully do it. Is there anywhere, or anyway to get the files convert to .obj?
thank you for any help
raiden_xavier
Autodesk Support
Autodesk Support
Hui @Anonymous ,
I see that you are visiting as a new member to the 3ds Max forum. Welcome to the Autodesk Community!
Thanks for sharing your issue.
You said you could load 3ds Max, but can't process the file. Which version of 3ds Max is it?
If you give us some more information about what you try to do and what happens I am sure we can help.
Look forward to hearing from you.
