Convert References back to Instances
PropChad
Message 1 of 1
PropChad
Is there a way to convert objects that were changed to a Reference, back to an Instance(s)? With References on CAD imports, you can often just add a modifier above the Derived-Object Line that is shown when objects are References, then delete that modifier and it'll remove the Derived-Object Line. That does not work with objects that you right click in the modify panel a choose "Make Reference". I thought maybe something would show up in the MAXScript Listener that could be reversed, but that Make Reference does not show  up here.
Replies (0)
