Connecting 2 objects in 3DS Max 2018
Message 1 of 21
Hi. I need help how to connect this flange with the tube in  Max 2018? A step by step guide will help me. I do it until this point with the Attach, but is not good at all.  Screenshot (23).png
Thank you.
Your post subject line has been edited by @hagen.deloss: 2 objects connection
Replies (20)
Message 2 of 21
hagen.deloss
Hi @Anonymous
Great to hear from you on the forums!
Before I can help you, I could use some clarification, is your end goal to have the two meshes combined into one? Are you using the attach tool from the sub-object mode from your command panel drop-down? here are a few other options that you can try from this article.
Use the Collapse Utility to collapse multiple selected objects into a single object:
  • Select all objects you want to collapse into a single object, then go to the Command Panel > Utilities > Collapse, select the Collapse options, then click on Collapse Selected.
Use the Boolean tool:
When you try to use the attach tool, is there an error that pops up? Or do the two meshes just fail to combine?
I look forward to helping you resolve this issue 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 21
Is my end goal to have the two meshes combined into one.And at the other end to add a flange,too.
Both objects are in editable Poly.
I try it with the Modify--edit Geometry -- Attach and not attached 100%, the gap is still there. The two meshes just fail to combine.
I try it with Utilities--Collapse . I selected both and still not doing the Union.
The blue object is to witch i want to add the yellow -flange. Screenshot (28).png
The Boolean : single and multiple selections. And is not doing nothing.
Screenshot (26).pngmml
I have no clue what i doing wrong.
Thank you.
Message 4 of 21
hagen.deloss
Hi @Anonymous
Looks like you may be able to use the Bridge tool! So the Attach tool only attaches the objects at the Object level, what you may be able to do is merge them at the Subobject level.
  1. Select the objects
  2. Attach them
  3. Select Edges, and then select the rim of both the bottom and top by shift+double clicking
  4. navigate to the Bridge Tool
  5. Keep in mind, this will only work if both objects objects are roughly the same poly density
Here are some screenshots for reference.
I hope this makes sense, let me know if you need any further help 😄
Hagen Deloss
Message 5 of 21
hagen.deloss
@Anonymous
Any ideas or questions regarding my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Hagen Deloss
Message 6 of 21
Screenshot (29).pngjjj
Hi. Sorry, but just today i received the email with your answer from Autodesk forum.
I think the objects don't have the same poly density .
  Have an idea how to check this and make roughly the same poly density? And after this to try again with your suggestion.
Thanks.
Message 7 of 21
hagen.deloss
@Anonymous
It would take a combination of 3D modeling tools to bridge your two objects together, I would suggest watching this video on the Graphite modeling tools in 3DS Max, by using the weld vertex tool, bridging individual polygons together, and some patience, you can merge the two shapes together.
Here is a video that explains some of the tools you could use to do this.
I hope this helps!
Hagen Deloss
Message 8 of 21
hagen.deloss
@Anonymous
Any ideas or questions on my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Hagen Deloss
Message 9 of 21
I still can't do nothing.Or is from my 3d max program , or from this 2 objects ( tube created by me and the flange from a script ) or i don't know what's going on here.
 If i select one object an edge is red and don't want to do the weld or bridge or target with the other object.
 How to post here this max. file to try it yourself on your pc?
Message 10 of 21
hagen.deloss
@Anonymous
I would love to test your file on my machine, to attach a 3DS Max file on the forums, first zip up the file, then you can use the attach feature 😄
Hagen Deloss
Message 11 of 21
   Look at the file ,is so little and i can't post it.What i'm doing wrong?
Message 12 of 21
hagen.deloss
@Anonymous
Hmm interesting, I'm able to attach a zip file just fine...you are using chrome, right?  I would say a .zip would be best, as opposed to a .7z that you have in your screenshot maybe.
If using a different web browser, and a regular zip file deosn't work for you, please let me know!
It may be something that @aaron.tw can help us figure out 😄
Hagen Deloss
Message 13 of 21
aaron.tw
Hey @hagen.deloss - thanks for tagging me here. We'll look into getting things set up with that filetype 🙂
Aaron Weiss
Message 14 of 21
Here is the file.
Message 15 of 21
I succeeded to send the zip file , but not from max. in zip. I converted the max. to 7zip and after this one to zip. file. Very hard to find this way of sending the max.file on the forum.
Message 16 of 21
hagen.deloss
Hi @Anonymous
the two objects you gave me were Meshes, I converted them to poly's, which work better with the graphite modeling tools.
The 2 objects had a lot of overlapping faces and were closed geometric shapes, which is part of why the Bridge tool didn't work for you.
I have attached a file walking through the steps I took to get 2 similar shapes merged.
  1. create 2 cylinders with an equal number of sides.
  2. convert those objects to editable poly.
  3. Attach the objects together.
  4. in the faces Subobject mode, delete the poly faces where you want to bridge.
  5. in the edges subobject mode, double click the edges you want to bridge together.
  6. select the bridge tool.
I hope this clears up any confusion on how to use the tools 😄
In regard to the object you are trying to edit together, I would suggest walking through the above steps first, and seeing whats missing!
Hagen Deloss
Message 17 of 21
    If i start from beginning with all my project will succeed. Let try to tell me how to do a flange --ellipse inside (like my )and to be adjustable the inside size , with 4 round-holes .lap-joint-flange.jpg   The neck also to be adjustable;i need a flange to be father and the other mother.  And after i do this new flange i your steps to Bridge with my tube
Message 18 of 21
hagen.deloss
Hi @Anonymous
Thanks for the reply! I'm still working through what attributes you want to be editable/adjustable, with this type of complex shape, it may be a little difficult to keep all elements as adjustable, and merged into the same shape.
In regard to the holes in your lathe, I would recommend using a boolean operation! When 2 objects intersect, a boolean can help merge, union or subtract those shapes. Here is what that would look like on the object you are envisioning.
I have attached a similar file below that you can test on using the boolean operation already applied.
To create an adjustable mesh, you may want to model the shape in Splines, and use the Bevel modifier instead, here is a video walking through how to do that.
I hope this helps!
Hagen Deloss
Message 19 of 21
I do it from the video ,but is not what I need.
Screenshot (51).png from front view the 2 flanges I need .the neck from one is higher ( 2mm ) and the other is less inside the flange (-2mm) . when I stick together are not sliding from each other.
Screenshot (49).png here I do it both with extrude . To the inner ellipse I need thickness of neck to be 1mm. I give it thickness ,but I don't know how to fill it. Is a way to fill the inside of flange totally? but the holes and the middle ellipse to not be filled? After is fill it can I go back and change just the inside ellipse or other object alone , or not? in this way can be Union with the tube?
Message 20 of 21
hagen.deloss
@Anonymous
I would first say that this may be a job better done in something like Autodesk Inventor, or a similar tool.  3DS Max is primarily used for lighting, rendering and modeling in film or non precise product rendering.
If those shapes are made from splines, and you need them to retain their scalable, editable nature, I believe the best way to create this object is with a series of boolean shapes, here is what that would look like.
Talk to you soon,
Hagen Deloss
