Cloth sticking to collision object issue
Message 1 of 13
Hi there,
I am having an issue with my cloth simulation. Scene file https://www.dropbox.com/s/qoinqmt5j66mtow/Battle%20Over%20Dallas%20-%20For%20Autodesk%20Area%20forum...
Issue is that at some point during the simulation, a cloth vertices will stick to a collision object and never get disconnected. I have messed around with it a bunch and have changed more things than I could fully list here(including depth, offset, garment density, cloth simulation step, etc), but I cannot identify the issue. In the attached file you can see it happens at frame 180. Truncating my simulation to before frame 180 and simulating again does not fix the issue.
I'm more than happy to try any suggestions! Thanks in advance!
Replies (12)
Message 2 of 13
MedalHellWay
Your scene works well for me. No cloth sticking to collision object, so I can not help you ...
Tip: when you create a rectangle to create the cloth, transform it in editspline and break the vertex before inserting the modifier Garment Maker; it works better in the corners of the mesh...
Message 3 of 13
Thanks for your response! If you go to frames 180-188 in my scene file you should be able to see that some vertices on the buttom of the rectangle/cloth are sticking to the wall and wall base.
Could you take another look? I would greatly appreciate it.
On another forum someone told me to attach the two collision objects near where the cloth is sticking, and then weld them. I successfully attached them but I tried welding the edges and the vertices but have been unable to successfully weld.
Message 4 of 13
MedalHellWay
The video (attach) shows the frames 0 to 190... all ok !! from 180 to 190 nothing strange...
Message 5 of 13
I do not see a video...
Message 6 of 13
MedalHellWay
The file attach on my first reply!!! 😄
Message 7 of 13
I was wondering what that was...a .rar video file? It wont uncompress or play in vlc...
I tried chaning extension to some video formats but that didnt help...
Message 8 of 13
MedalHellWay
???? You must unzip the package with winrar, 7zip ecc... Inside there is a video in .avi called "_scene"...
Message 9 of 13
strange. the rar would not unzip no matter what program i used. it just gave an error.
anyways, im not sure what you are talking about because there certainly is an issue in that file. but, never mind as I received help on another forum.
the solution was to attach and weld the two collision objects that were sticking to the cloth.
Message 10 of 13
Steve_Curley
Don't know what you're doing then because I just download that file, extracted it with 7zip and played it. There's nothing wrong with the avi at all. Try redownloading it.
And while you're doing that, please let us know which version of Max you're using - could potentially be an issue in an earlier release which isn't there in new(er) versions.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 11 of 13
Strange. I guess my download was corrupted...
In any case, as I stated earlier there definitely was an issue with this, not sure why you didnt see it. On other forums people saw the issue in the same file and were able to help me.
Attach > weld for my collision objects was the solution.
Thanks for your time folks!
Message 12 of 13
MedalHellWay
Yes, with 7zip the file .rar is ok. Anyway, with 3dsmax2016 the simulation don't have any problem... happy for your solution!! 🙂
Message 13 of 13
Ah! I thikn I am using 3dsmax 2015. Maybe time for an upgrade 🙂
Thanks!
