- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm in progress learning how to 3D animate and use CAT rigs animating a character. I have a similar issue to another post from August 2019, when I go into animation mode, but only 1 specific bone for a sword won't move and rotate. it's not frozen I can select it and everything, I have the rotation sphere but it just doesn't move, all of the rest of the bones move absolutely fine it's just this one bone which I created for my characters sword.
I have tried the fix from the post from August checking my animation layers suggested by @ads_royje , but with no luck sadly. Also something else that could be part of the problem is all of the other bones that I select, in the "Motion" tab have PRS Parameters, Euler Parameters, Key Info (Basic), and Key Info (Advanced) when setup/animation mode is toggled on. The 1 bone that won't move or rotate has none of those options appear.
I'd really appreciate some help please, thank you!
