Cant open file
Cant open file
Message 1 of 19
Cant open file
Hi when i import cadd file version 2013 in 3dsmax2012 version some error is displayed .... @@@@ The Error code reported is enotimplementedYet....@@@@ ...wht is the problem ...
Replies (18)
Message 2 of 19
rendermaster
save your cad file into lower version
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 19
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
Did the post by @rendermaster solve this issue for you?  Thanks for the info!
Best Regards,
Message 4 of 19
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Message 5 of 19
I cant change it sir
Message 6 of 19
Sir i changed into lower version 2010 but still problem is there
Message 7 of 19
After importing object 2012 3ds object appear sky blue colour sir ...but i used different layer in cadd ....
Message 8 of 19
Alfred.DeFlaminis
Hello @Anonymous,
Thanks for the update.  Am I correct that you are able to import the file now using older format settings?  Would it be possible to attach a simple dwg file that has this problem so I can test things on my end?  I don't know AutoCAD so I doubt my ability to match what you've got, but I can look into the 3ds Max side of things no problem.  Thanks for that!
Best Regards,
Message 9 of 19
thnaks for supports sir . I send my  both dwg file n max file . then u can find out problem ,,,
Message 10 of 19
i send screenshot of cadd file n max file
Message 11 of 19
screenshot of file
Message 12 of 19
Alfred.DeFlaminis
Hello @Anonymous,
I opened the scene in AutoCAD and it seems all objects are on layer 0 or layer ele wall.  When Max imports the file it assigns random colors to the layers, you can change them as shown below.  (Or add materials in AutoCAD.)  Can you please try that for me?
Best Regards,
Message 13 of 19
K sir i will try
Message 14 of 19
Sir in that file i used 12 layer ... i will send that throught scren shot sir
Message 15 of 19
rendermaster
no problem also on my side
Message 16 of 19
Alfred.DeFlaminis
Hello @rendermaster,
I wasn't able to get these mats to show up like this... I even have the same settings on my preset.  Did you manually do that or did I miss something?
@Anonymous, are you all set now?  If so, please mark any posts by clicking "Accept as Solution" and thank you so much for doing so!  If not, did you have any problems assigning materials?  I'll do whatever I can to help.
Best Regards,
Message 17 of 19
rendermaster
i just modified the preset - Derive Autocad Primitives by: COLOR
Message 19 of 19
Hi to all,
I'm posting here, even my problem is different, but I assume its better than opening a new thread.
I have an old file I need to open in 2014 version.
As far I know, it was made in that version a few years ago, but I can't import it now.
I didn't use MAX a few years, so today I downloaded my license again to a new computer.
This is what Im getting on import:
2019-08-16 21_48_08-Untitled - Autodesk 3ds Max  2014 x64  - Student Version.jpg
These are the properties of the file I'm trying to import:
I'm rusted in MAX knowledge, so I hope this is not a very dumb question.
I need this file just to check something so, if we cant solve this problem quickly, I'm looking for the second answer: How to convert it in 3ds file, or can anyone do that for me?
Cause this type of file is importing without a problem:
Thanks in advance!
