Can't use the sign in button on the splash screen.
Message 1 of 14
Hi! I recently got a student license for 3DS max but I'm having trouble activating it. When I try to click on the "Sign In with your Autodesk ID" button, the splash screen closes for no reason. I managed to make 3DS max work by starting a Trial version, since I couldn't use the "Sign In with your Autodesk ID" button. My student license is valid, Windows and my drivers are up to date. Does anyone know if there's a fix or workaround? 😕
Replies (13)
Message 2 of 14
irishman_team_kilber
cannot you activate the student version from the help menu and enter your ID
Message 3 of 14
I don’t see any option to enter my ID in the help menu. Also I did a video so it’s easier to explain my problem. It’s start around 35s https://youtu.be/uk9pORAeKkE
Message 4 of 14
JM_K
Try installing the Autodesk Desktop Application, if you  haven't already and then open and sign into it. Now try to open the software. Hopefully 3DS Max will pick up the fact that you're signed in on the computer and will side step that log in process.
Insert witty comment here.
Message 5 of 14
Sadly it didn’t work
Message 6 of 14
it says eneter your serial number so you enter that serial that autodesk sent you to your email once you have registered the software,  or the help menu it says activate software.
try updating 3ds max service pack and hotfix see it that fixes the problem
Message 7 of 14
My liscense doesn’t have an serial number since we only use our IDs. 😕
Message 8 of 14
JM_K
OK, can I ask you to download and install the licensing update - https://download.autodesk.com/us/support/files/autodesk-licensing-service-update/win/adsklicensingin...
If you have antivirus installed on your system please turn it off prior to doing the installation and shut any Autodesk software that might be running.
An article about the update process:
https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-downl...1
Message 9 of 14
JM_K
Can I get you to have a look in this folder -  C:\Autodesk\Network License
Manager\Logs.
And if there are logs in there, please post the newest one.
Message 10 of 14
lynn_zhang
Hello @Anonymous ,
Have you had the chance to try the above suggestions from @JM_K and did you have any success? Let us know if you still need help!
Lynn Zhang
Message 11 of 14
annelisefreund
I'm having the same issue, I have a student license (no serial number or license activation key provided) and I'm currently on a trial period because it wont let me sign in.
Message 12 of 14
Hey. For some reason it happened because I had it installed on my second hard drive. I uninstalled it and reinstalled to my C:Drive and it worked for some reason. I also had to do a clean uninstallation. If I remember this is the video I watched to do it : https://youtu.be/4O3aocEO4Tg. I hope that this will work for you too.
Message 13 of 14
annelisefreund
Thank you so much! The video was extremely helpful, and worked like a charm!
Message 14 of 14
karambix
Community Visitor
Community Visitor
is there any solution to this problem without the necessity of reinstalling the program from other drive to C drive? I don't have enough space on C drive that's why it is installed on the other one. Unfortunately the same problem as mentioned above appears..
