Can't use bitmap on plane
I try to set up a plane as a background. In order to do that, I have tried to create a plane, use material editor to add a bitmap to a slot and drag it to the plane. However, each time I do that, 3DS Max doesn't let me drop it in the plane. (A prohibition sign appears beneath the cursor).
I'm running Windows 7 Ultimate 64-Bit
                 3DS Max Design 2013 64-Bit.
Steve_Curley
Materials go onto objects, not bitmaps. Create a Standard material, add the bitmap to the Diffuse Map slot, drag the Material to the Plane.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Had the same problem and I think it was because the plane Freezes itself so that you can't accidentally move it while manipulating stuff on it. If you're having this problem try unfreezing the plane. Worked for me.
