3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Can't Save Project due to Backup File Error
22 REPLIES 22
Message 1 of 23
32135 Views, 22 Replies
I have been working on projects recently and when I save, an error keeps popping up saying that it is unable to create the backup file MaxBack.bak in the autoback folder. This error is preventing me from saving. How can I fix this?
22 REPLIES 22
Message 21 of 23
laomusic_arts
in reply to: luismestre
I just had this issue which I solve by turnning of "Backup on Save" under: Customize/Preferences/Files/Backup on Save It is always useful too to use this script to free memory : macroScript FreeMem category:"MyScripts" tooltip:"Free up memory" ButtonText:"Free Memory" ( gc() freescenebitmaps() clearUndoBuffer() ) Hope this helps you guys too !
Message 22 of 23
in reply to: Alfred.DeFlaminis
I have also occasionally run into this issue. Sometimes if you interrupt the max auto-backup (by pressing escape) you might be left with Autobackup.max.s$v files that remain in the autoback folder. You will get this error as a result until you delete the .s$v files.
Message 23 of 23
MKJOR
it happened to me today, as you mentioned Google Drive was the issue, plus BOX (uploading platform) made the same issue for me. The only thing i was doing it is saving copy as because the save is not effective at all. But since i moved the file to another folder its all solved.
