I can't find the new Blended Box Map.
I just checked on 3 different computers (3 separate installations), on all computers, 3ds Max 2017.1 update is installed.
Also, on all computers, 3ds Max come from Factory Design Suite Ultimate 2017 en.
One computer is Windows 7 and the other two are Windows 8.1.
Just to show you that i am looking at the right place, here's a print screen:
What Renderer are you using? MentalRay is NOT supported (and yes, this means what you think it means...)
I think supported are (someone correct me):
Scanline
Quicksilver
VRay ?
Arnold
Hi Aon, thank you very much. I think you are right, unfortunatly. I just tried with scanline and i have the map.
At the risk of sounding redundant. I cant find it even with the scanline renderer set. I have vray installed could it somehow be effecting it?
I am using max 2017....
thanks
Hello @Anonymous,
Make sure you have the latest update installed, it was part of a 3ds Max update. You can find them on Manage.Autodesk.com or through the Desktop App. Thanks!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
