Can't find open group head to close
has anyone has this issue and how do we correct it in max 2014, need this badly
Steve_Curley
De-select everything, Zoom Extents All. An open group will have a pink bounding box. Alternatively, select a single object which is in the open group and run the following short script.
while selection[1].parent != undefined do
   select selection[1].parent
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
damm i solved it too fast i would have loved to try this, what i did was creat a new object and make a new group, then select each trouble object and attach it to the group, it worked just fine now i dont have the issue in my file anymore, thanks again steve for your help, as usuall ur a life saver!
Well it's been a long time but maybe it can help someone :
for obj in $ do
	if isGroupHead obj AND isOpenGroupMember obj then
		print(obj.name + " - isOpenGroupMember  : " + isOpenGroupMember obj as string +
				" - isGroupHead : " + isGroupHead obj as string)
		setGroupMember obj false
		--setGroupOpen obj false
When this error shows up the group head is flagged as a group member as well as a group head, so we just have to detach it.
Don't forget to make backup before saving the file....
dhalsin_leo
Community Visitor
Community Visitor
I was having the same problem, I was able to select an object from the group and create a new group, then I ungrouped it and did that with the rest of the items until they all had no group anymore.
