Can I convert vray materials to standard?
Is there any option for converting vray materials into standard? I've seen the other way around but nothing to what I'm actually looking for. Do I have to create all the materials again from zero? thank you.
10DSpace
@Anonymous
The Physical material or Arnold Material is a better match for a vray material than the standard material, particularly if you are using a PBR workflow.  You might find the Max docs link below helpful.  It includes a link to 2  different converter utilities for converting Vray materials to Physical materials or Arnold materials.
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-convert-VRay-materials-to-Arnold-materials-for-rendering-in-3ds-Max.html
lynn_zhang
Hello @Anonymous , welcome to Autodesk Community!
Just checking to see if your problem has been solved. Did the above response from @10DSpace X help answer your question? If yes, please click on the "ACCEPT SOLUTION" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
maxtoolsQUR5M
To convert V-Ray materials to Standard materials, you can also use "V-RayMax Converter PRO"
RobH2
I second that, "V-RayMax Convertr PRO" is really excellent, not very expensive and a life saver over the long haul. I've used it for years and could not function without it.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
