Build Corner does not work
Hey,
I wanted to use built corner in 3ds Max 2016 but it didn't work. I'm pretty sure I used it properly, actually I did it just how they explained it on the website:
http://help.autodesk.com/view/3DSMAX/2016/ENU//index.html?guid=GUID-D07B4F5B-33AE-4544-A905-A52A678C...
Why is it not working?
Please help me! Is it a bug?
Thank u in anticipation
@Anonymous wrote:
Hey,
It seem only to work with editablePoly as a base object but NOT with the editPoly-modifier.
Could be a limitation or bug, but since 'Build end' works with both editablePoly and editPoly i think it`s a bug.
I'm sorry it took me so long to response, but thank u a lot for this answer. Should I report it as a bug, because it is just useful in an none destructive workflow, because 90% of all 3d artists I use the modifier way?
Yes, if you wan`t this issue fixed you should report it.
Still not working in 3ds Max 2019 on edges in Edit Poly mode.
It will work in Edit Poly mode though by selecting the verts.
I run the following macro on the edge selection:
$.modifiers[#Edit_Poly].ConvertSelection #Edge #Vertex
subobjectLevel = 2
$.modifiers[#Edit_Poly].ButtonOp #RemoveEdge
macros.run "PolyTools" "BuildLoopCorner"
Essentially, it converts the edge selection to verts, deletes the edges and runs the loop corner command.
Kranos_Orphydian
2020.2 and its still doesnt work on Edit poly modifier. Man they are bare to useless this way. None from Autodesk havent give any reply to this.
