I've recently switched to 3dsmax 2021, and I was really disappointed (to say the least) that it doesn't seem possible to duplicate editable poly's sub-objects using Shift + LMB, whereas it worked for ages !! ... this is what I did:
- select an editable poly object
- switch to any sub-object level, let's say Element
- Shift + LMB and drag in any direction
--> the sub-object is moved, not duplicated !!
Could you please fix this ASAP ??? really annoying ... all the more that this has worked perfectly for ages !
Thank you,
Best regards.
