BUG 3dsmax2021 - no more possible to duplicate sub-objects ???
NicoC
NicoC
I've recently switched to 3dsmax 2021, and I was really disappointed (to say the least) that it doesn't seem possible to duplicate editable poly's sub-objects using Shift + LMB, whereas it worked for ages !! ... this is what I did:
- select an editable poly object
- switch to any sub-object level, let's say Element
- Shift + LMB and drag in any direction
--> the sub-object is moved, not duplicated !!
Could you please fix this ASAP ??? really annoying ... all the more that this has worked perfectly for ages !
Thank you,
Best regards.
CAMedeck
Use CTRL+SHIFT+drag now to duplicate polygon selections.  In Editable Poly, they've changed the SHIFT+drag to extrude the selection rather than just duplicate it.  It takes a little getting used to, but I will say that I like the new funcionality.  Reminds me of the ease of Sketchup modeling.
Chris Medeck
NicoC
Hello camdeck 🙂
Thanks a lot, I wasn't aware of this slight change ! if it was mentioned somewhere, I definitely missed it ...
Regards.
Diffus3d
That new extrude is pretty great, but my muscle memory hasn't updated fully yet either.  😛
