Hi @whitebirchstudios
Is the script functioning in other versions of max? Can you view the script or is it encrypted? What is the name of the script?
I am not sure what you mean by "browse your drive", but I have a number of scripts that I have written that open the file browser dialogue using the following command:
fdir = GetSavePath caption: "Select Directory for Export" initialDir:(maxFilePath)
I have not had any crashes with any of these scripts in Max 2020.3 (or any other recent version of Max). Do your crashes occur with the opening of the file open dialogue or at some other time?
If you want to test a simple export to an .fbx file of a selected object in a scene which opens the browse dialogue, you could run the following snippet and see if you are free from crashes with it
theClasses = exporterPlugin.classes
_objIdx = findItem theClasses FbxExp
-- without *.FBX export dialog
exportFile (fdir + "\\" + $.name) #noprompt selectedOnly:on using:theClasses[_objIdx]
Just some troubleshooting thoughts for you as a starting point. It might help narrow the issue down a bit.
