Issue with 3ds max, black background behind tooltips
Lenovo Legion y540
GPU 0 - Intel UHD Graphics 630
GPU 1 - 1660Ti
Displaying on the second screen, where it is responsible for displaying 1660Ti, this is not observed
3ds MAX v.25.3.0.3640
Solved by raiden_xavier. Go to Solution.
Solved by Diffus3d. Go to Solution.
Hello @svvbrd ,
I doubt 3dsmax 2023 is supported on Intel UHD Graphics 630, so it makes sense there are display issues. In 2022 it was only partially supported I think. I'm impressed it displays anything at all to be honest.
My preference is to disable onboard graphics in the BIOS, there's little benefit to having the onboard graphics enabled if you have another 3d card in there. It causes problems with some real-time renderers and leads to headaches down the road.
Best Regards,
Alfred (AJ) DeFlaminis
Thanks a lot, probably yes. Although if you look from the task manager, it works with 1660Ti, but before I didn’t have 630 turned on, after updating the BIOS it most likely turned on
Hi @svvbrd,
Thanks for sharing your issue with us.
Are you confirming that updating the BIOS resolved the black edge issue?
We look forward to hearing from you.
Many thanks.
