Bitmap relink doesn t work
valentindobre2003
valentindobre2003
Community Visitor
Community Visitor
I just tried to add my textures via relink bitmap but it does nothing,I select the folder and then after I press relink it does nothing,I searched everywhere for solutions but still nothing,what can I actually do?
dgrehan
Try clicking the 'Ignore Case' tickbox, sometimes that helps.
Although I have heard of it not being as good at finding bitmaps as it used to be, maybe something changed in Max or Relink Bitmaps. Some people have been trying 'Project Manager' 'Find and Replace' instead, and that has worked where Relink Bitmaps didn't.
darawork
I just dragged and dropped an older version "Relink Bitmaps 2.14" .mzp into the 3DSMax scene window.
It replaced my 2.16 version. I ran it and it found a lot of missing Bitmaps that 2.16 didn't find.
So it looks like the solution for now is to 'downgrade' to Relink Bitmaps 2.14.
The only thing that has changed recently for me is a few Windows Updates, so that might have broken 2.16?
Here is a direct link to Relink Bitmaps 2.14
Maybe give that a go.
Regards
@Anonymous
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
CAMedeck
Strange that no maps are showing in your list, even though you've got All Bitmaps checked.
Note that if your materials aren't using Bitmap or VRayBitmaps, the script won't recognize them.  Some imported materials from Revit will use Autodesk Bitmaps which will need to be converted.
Chris Medeck
Mr.Mxyzptlk
You could also try using kstudio's project manager. They have a demo and it's much more robust.
