Bitmap doesn't showup even after unwrapping UVW modifier is applied
Hey there,
It maybe a noob question but I'm unable to see my bitmap after unwraping uvw modifier is applied. I'm following the tutorial here   and at 2:04 to 2:27 for some reason same thing doesn't happen to my model. Bitmap is not applied to my material.
Why is that?
I'm attaching a video below to fully illustrate what I'm doing.
CAMedeck
In Slate, right click on either the Bitmap node or the Material and select Show Shaded Material in Viewport.  Right now, your material isn't showing up because it hasn't been told to.  It is often enabled by default when making a new material, but apparently did not do this in your scene.
Chris Medeck
Thanks! It worked.
