Our company is decommissioning our server used for Max library data and everything will be moved to an offsite data server. Is there a way to automate the process of repathing the textures used for our model library assets or are we going to have to use relinker manually on every file?
Solved by darawork. Go to Solution.
Colin Senners 'Relink Bitmaps' can be run as a batch file using 'Batch It Max'.
Scroll down to the bottom of the page for instructions:
https://colinsenner.com/relink-bitmaps/
Hopefully this will sort it out for you,
@Anonymous
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
I used to use a beta version of Library Track/Relink by Pixamoon. The release version is pretty cheap, and it is a very powerful tool.
https://www.pixamoon.com/product-page/library-track-relink
I've never used the full release, but the UI looks to be much easier to use than the beta I had.
Chris Medeck
