Backburner won't render image sequence
DannyTheGamer
DannyTheGamer
Hey guys, I'm trying to render a scene as a .png image sequence through Backburner.
However, unlike when I render using simply 3DS Max, Backburner doesn't save the sequence as multiple .png's, it simply overwrites the same image over and over again.
How do I fix this?
CAMedeck
Are you using Batch Render?  I recall having the same issues when rendering a sequence through Batch Render but having the main render set to Single.  Setting it to anything else fixed it, and I typically would set it to Range 0-0 so I could still do test renders of a single frame.
Chris Medeck
DannyTheGamer
Thanks man, it worked! You solved my problem!
Wonder why it happens though xD
