Ok here's what I had to do recently for some clean reinstall systems. With windows10 you can set ipv4 to a higher priority than ipv6 this appears better than disabling ipv6 altogether which may impact some other things adversely.
Hit start - type CMD to open an administrator level command prompt window -then follow steps below:
(taken from https://kb.firedaemon.com/support/solutions/articles/4000160803-prioritising-ipv4-over-ipv6-on-windo... )
In your elevated command prompt type:
netsh interface ipv6 show prefixpolicies
You should see the following output:
Precedence Label Prefix
50 0 ::1/128
40 1 ::/0
35 4 ::ffff:0:0/96
30 2 2002::/16
5 5 2001::/32
3 13 fc00::/7
1 11 fec0::/10
1 12 3ffe::/16
1 3 ::/96The first line with a precedence of 50 is the IPv6 loopback adapter. The second line with a precedence of 40 is the IPv6 default gateway. The third with a precedence of 35 is all IPv4 compatible addresses. To change the precedence, type the following:
netsh interface ipv6 set prefixpolicy ::ffff:0:0/96 46 4
The value 46 is the new precedence. Windows uses this value order prefix lists based on destination. The lower the value, the less preferred that destination is. The value of 4 is the label. Windows uses this value to order the source preference based on the destination prefix. Then type:
You will now see the priority has changed as follows:
50 0 ::1/128
46 4 ::ffff:0:0/96
40 1 ::/0
30 2 2002::/16
5 5 2001::/32
3 13 fc00::/7
1 11 fec0::/10
1 12 3ffe::/16
1 3 ::/96 I hope that helps some people.
Feedback for Autodesk staff: (@jon.bell ) Autodesk are selling an animation product - but your code teams no longer feel like you have to update or support parts of the product that are essential to making animation production possible e.g. network rendering dialogues inside max are broken and revert to default settings as appeared in Max2019 wasn't patched, still broken in Max2020 and still broken in Max2021. Backburner gets more and more broken each year, requiring more and more specialised work arounds (especially with the prefer ipv4 over ipv6 stuff). Getting server to automatically start up at boot gets more and more annoying each year. Even non-critical stuff stuff like Monitor for example can't even tell how many CPUs modern computers have (can't count above 32cpu cores) appears symptomatic of just not caring about a significant segment of customers. List goes on and on. Why isn't there a proper 64Bit update to backburner systems installed as default?
What's the end goal, losing your animation customers? An animation product that doesn't properly support rendering large numbers of frames in realistic timeframes is not a very viable animation product.
