Avoid reflaxions from HDRI on a material.
Darwin33
Darwin33
I have an scene iluminated with HDRI and I am happy with the level of ilumation, but I would like to avoid the reflections of the HDRI map on a metal material.
Best regards
I'm not sure what material, specifically, you are using but have you turn down - or off -- its reflectivity values or glossiness?
Darwin33
If I turn down glossines on the reflect tab I can avoid the reflexions, but the material doesnt bright as much. Is there any other solution that leaves the bright on the material without the hdri map reflected on it.
CAMedeck
If you happen to be using V-Ray, you can set an override map for reflections and refractions.  Open the Render Setup dialog, go to the V-Ray tab, and near the bottom is a rollout for Environment.
If you are using Mental Ray, I'm sure there is a similar process to get the same result.  It has been a few years since I've used Mental Ray, though, so I'm not exactly sure how to do it.
Chris Medeck
rendermaster
and if you are using mental ray, under special purpose maps, you can overide the environment reflection there.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
