Hello
I have problem with 3dsmax 2011. The scene saves for a very long time. I attached the file with just one box which should save in a blink, but it take about 3-4 min. Another scenes saves even longer.
I tried cleaners and this script:
while (numNoteTRacks TrackViewNodes.Max_MotionClip_Manager > 0) do deleteNoteTrack TrackViewNodes.Max_MotionClip_Manager (getNoteTrack TrackViewNodes.Max_MotionClip_Manager 1)
(noteracks = 0)
but it didn't help. In addition, saving same file in max 2012 is fine.
Also there are no colisions in reactor.
I tried to call Autodesk, but they refused to help and send me to the distributor... I have 7 licences and what? Please HELP me.
Please help
Solved by spacefrog_. Go to Solution.
You scene is "infected" with the note track problem. But not the usual one which generates loads of note tracks in the Max_MotionClip_Manager, which you tested for, but one that generates them in the Anim_Layer_Control_Manager.
The Cleaner script does'nt look there
You can see them in the Trackview under the global node "Anim Layer Control Manager".
How they got there i don't know - Is this a fresh scene ?
Anyways the number of note tracks in there is insanly high ( 191726 ), which you can get by entering "numNoteTracks TrackViewNodes.Anim_Layer_Control_Manager" in the listener
To fix the issue using your script simply replace every Max_MotionClip_Manager occurance with Anim_Layer_Control_Manager and the script should work...
But that will take a while ...
Realy realy thx!!!
IT WORKED PERFECTLY!!!!
I couldnt find that fix anywehere.
I'm making large scenes, and even copy the camera make that problem.
Now i found this problem in some other objects and now i can fixed them.
Big thanks one more time.
You're welcome 😉
After i cleared your scene, i noticed that there are some Animation Layers in the scene. Don't know if this is intended or come from an import, from your "maxstart.max" file or anywhere else.
But i have heard from other people that Animation Layers caused problems in general ( don't know if it was that Note Track problem though ...). So maybe it would be best to get rid of them in your scenes ....
Hi again
I believe that you have good point with Animation layers
My other file saves very long and its not node problem
The file contains a lot of empty parameters under: Track View -> Anim Layer Control Manager -> Anim Layers
But i cannot delete them.
Any idea how to remove them ?
