Array Missing in the modifier list
tehts
Message 1 of 12
tehts
Array missing in the modifier list after update to 3ds max 2023.3.5, any solution?
Replies (11)
Message 2 of 12
tehts
No one update to 3ds max 2023.3.5?
or everyone update to 3ds max 2023.3.5 but no one facing Array Modifier missing issue?
Message 3 of 12
RobH2
I can confirm that it is missing from the normal 'Modifier' list. However you can find it in the 'Tools' menu when you need to use it.
You should report this as a bug. Do that here:
Bug Reports:
https://www.autodesk.com/company/contact-us/product-feedback
I might suggest that anyone who doesn't share files and has no Security concerns not install the 3.5 update immediately until it is resolved. It appears that nothing new is in it excpept Security Fixes. From what I can tell, Update 3.0 brought some functionality, but 3.5 is merely Security related.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 4 of 12
tehts
@RobH2 ,
That one you mention here is difference the missing Array i mention here sir, try update your 3ds max to 2023.3.5 and go to Modifiers menu -> Parametric Deformers -> see whether you can find the Array Modifier or not, but before you update go to the menu, you can see the Array Modifier.
PS: for those who update to 2023.3.5 and got Array Modifier missing like me, uninstall your 3ds max and reinstall 2023.3.4, that's how I fixed this issue.
Message 5 of 12
ernestoflores14354901
Como puedo regresar a la version anterior?
Message 6 of 12
tehts
click here to download the previous version and install it.
https://manage.autodesk.com/products/updates
Message 7 of 12
Gracias, ya pude solucionarlo
Message 8 of 12
petenunneley
In case anyone else finds this there is a workaround without having to reinstall max, you can go to your add/remove programmes and uninstall 'Autodesk Advanced Modelling Tools for 3ds Max 2023', then go into C:\Autodesk\Autodesk_3ds_Max_2023_EFGJKPS_Win_64bit_dlm and re-run the '3dsmax-component-mnplugins2023-1.1.0-025' to re-install the advanced modelling tools.
This worked for me but would be good to get confirmation.
Message 9 of 12
e_flerkoPT699
Thank you for this solution! It works
Message 10 of 12
andreiamatias
Community Visitor
Community Visitor
You rock my friend, thank you!
Message 11 of 12
RobH2
@petenunneley  Thanks for posting this. This issue has been plaguing users for years. You have made a lot of people happier...  🙂
Rob Holmes
Message 12 of 12
Diffus3d
This should be an article.
