I have a problem in 3DS Max - whenever I begin a render, the Arnold Renderview opens in the bottom right corner of the screen, meaning I have to drag it into view to see it in full. This isn't a problem, but when the window is dragged, it loads gradually to fill in the pixels that were previously off screen (very slowly).
I have attached a photo below of the process mid-load, the white pixels are currently being loaded in. I should mention that the program is also unresponsive while this is taking place.
Any help would be appreciated!
Thanks ๐
Solved by CiroCardoso3v. Go to Solution.
I would start by first installing the latest update
And see if that helps with that bug.
You are welcome, glad it worked.
