Arnold Renderer Bug?
I_Megaman_i
Message 1 of 23
I_Megaman_i
why is it happening, Ive tried everything I know
  • its NOT a UV problem
  • I have tried creating new materials and new texture files, nothing
  • I think, it all started when I changed a color profile. Right now it is set to "Unmanaged"
Replies (22)
Message 21 of 23
I_Megaman_i
@Diffus3d wrote:
I want you to be happy, and if that helps... sure.   What is the issue that needs to be solved though?  You don't like the idea of using a different texture type or the opacity slot?  Or did it not work when you tried it?   Just let me know what I'm looking for and I'll do my best.
Best Regards,
Maybe you`ll get more luck with fixing the dark textures.
Message 22 of 23
Diffus3d
Oh, sure I'd be happy to take a look.
Best Regards,
Message 23 of 23
CiroCardoso3v
So far it seems to me that the problem is that you are bringing the maps into 3ds Max with the wrong color space. Everything that is scalar data, like bump, normal, roughness, displacements, needs to be set to RAW and not Automatic, which will turn is sRGB. Even if you don't use color management you need to set the gamma to 1.0 and not 2.2.
Before
After
Gamma needs to be set correctly
Before
After
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
