Anyone know if its possible to vertex paint two map channels at the same time?
oliver8877
Observer Observer
oliver8877
Observer
Observer
Anyone know if its possible to vertex paint two map channels at the same time? so you could paint one colour in say map channel 3 and at the same time paint a different colour in map channel 8 ? for example
If not would you be able to do this by writing a max script??
thanks for any help
Alfred.DeFlaminis
Hello @oliver8877,
I've looked around at your question here and I don't see a way to paint on two channels at once, but the good news is that you can simply copy the vertex paint modifier and paste the copy on top, then change the channel on the copy to get both channels that you need.  Does this work for you?
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred.DeFlaminis
Hello @oliver8877,
Just following up on this, did the copy/paste idea work out for you?
Best Regards,
