any trick to close or open all the rollouts in the Command panel?
KathyKathy
KathyKathy
Is there any trick to close or open all the rollouts in the Command panel? Thanks!
miauuuu
Right click in the Command panel(outside the controls, for example right click the title of an rollout) and you will see a RC menu with an option to Close All or Open All.
https://miauu-maxscript.com/
KathyKathy
@miauuuu Thanks! Yes, I see the right click menu you refered to after right clicking here and there. It seems that right-clicking the title of an rollout does not call out the menu. Right-clicking the blank area of a unfolded rollout does get it appear. A little tricky.
miauuuu
Tested on max2020 and 2022, right click the title of a rollout always shows the RC menu.
KathyKathy
@miauuuu Sorry. I'm using 2015. Thank you for checking!
