AEC errors again :(
AEC errors again :(
Chri688m
Message 1 of 68
AEC errors again :(
Chri688m
Hi everyone im faced with a error regarding AEC.
When i am trying to make a floorplan with alot of different walls attached together and i begin to place walls to boolean with the aec doors / windows it crashes after a certain amount of door or windows are places this is a common issue in AEC for me atleast...
I posted a video on youtube to show what exsactly happens - i have also run windows logs to check what windows sais and it is described as a Application hang or fault bucket
UPDATE: If i chose not to attach the walls together but have 35 different walls it does not crash although this is not optimal at all 😕 (Would still like a solution if anyone has one)
https://www.youtube.com/watch?v=MpIL342m_Mc&feature=youtu.be
Smiley Sad
@Alfred.DeFlaminis Maby you know a fix to this issue aswell as the other issue regarding AEC? - in case you want to check out the file then i can send it to your email...
_______________________________
One Does Not Simply Receive Kudos!
Replies (67)
Message 21 of 68
Alfred.DeFlaminis
It shouldn't crash but these tools predate the 64 bit conversion of Max.  I wouldn't rule out a fix to at least prevent the crash.  Sometimes all it takes to change things is a good attitude and a proper repro scene.  In the meanwhile subdividing the segments works like a charm and I believe this is the intention of that feature in the first place.  Did you find that it worked when you subdivided?
Best Regards,
Message 22 of 68
irishman_team_kilber
Don't know how to sub-divide the AEC walls that is a new one on me, i can divde the walls when i go into the segments
Message 23 of 68
Alfred.DeFlaminis
Message 24 of 68
nope still the same still crashes, i give up now i mite as do what i was doing before crashing a new window and copying the dimensions over from one to another, but is the best i can do
Message 25 of 68
Alfred.DeFlaminis
I made a screencast of it working.  I framed the video so it's only the window and the wall that are visible, is it ok if I post it?
I can't understand why that wouldn't work for you.  Could you send me a screencast of what happens when you try?  Thanks!
Best Regards,
Message 26 of 68
sure why not it's okay
Message 27 of 68
Alfred.DeFlaminis
Thank you @irishman_team_kilber,  here was my experience.  (Win7).  I will test on W10 this week, currently out of office due to sickness.  I did repro the crash originally but adding the segments helped.  Maybe you were altering a different window or door and I could look closer at that one.  Thanks!
Best Regards,
Message 28 of 68
@Alfred.DeFlaminis that is what i did but i am using the Fixed windows, and max still crashes. i give up i mite as well continue with what i was doing!
Thanks anyway
Message 29 of 68
Chri688m
Hi guys - sorry for the late reply has been out of office..
Alright, so i don't see why sub-dividing the walls would help this issue at all, although i did find out that you can actually parent the doors and windows into the walls before attaching which lets 3ds run completly fine... Its an annyoing workaround but it kinda works i guess : /
Message 30 of 68
yeah but it's to do with the clone on in max is doesn't matter what I do it still crashes
Maybe max doesn't like me? if i create a completely new scene then max works fine but as soon as my scene gets bigger and i try and copy the doors/windows it crashes.....
Message 31 of 68
Chri688m
Well i mean, i work with both maya and max and i think theres quite a big difference on how the different programs react.
I think maya overall works alot better as i think it way more stable, wheres in max your daily facing annoying problems or crashes... 😛
But maby im just stupid at max 🙂
Message 32 of 68
Alfred.DeFlaminis
Message 33 of 68
Chri688m
I have attached a file, if i try a move some of the doors it will hang and then crash..
One Does Simply Receive Kudos!
Message 34 of 68
Alfred.DeFlaminis
Hello @Chri688m,
Again, subdividing the segments fixes this.  You can see already the misplaced triangles all over the scene before you move the doors.  Too many walls have bad booleans due to poorly parameterized geo.  I think you guys are underestimating the importance of providing the boolean operation the right geometry.  Still, it shouldn't lock up as it does and I'll log that, but this is working fine once I subdivide the walls.  Also, you don't have to make your walls all 1 piece.
I've reattached the scene with segments subdivided.  You can move the doors easily on this one now.  I just randomly subdivided things all over until the triangles went away, it could be cleaner but I wanted to fix it in 20 seconds or less.  EDIT:  I unlinked all the objects before I subdivided the segments because the geo was too dirty.
Best Regards,
Message 35 of 68
Chri688m
Whenever i try and perform the divide max crashes...
Message 36 of 68
max doesn't like you going beyond the scope of the program, if you create walls and you find them widith to big and you move the vertices, you copy the windows/doors bang it crashes, so you will have to delete & and recreate them
God Autodesk should of improve this AEC by now it's deffo stupid.
Message 37 of 68
Alfred.DeFlaminis
Hello @Chri688m,
Yes, you need to unlink all the doors and windows first.  I had to as well.  Currently the boolean inputs are stressing it out too much, so the segment won't work until you unlink.  Can you please try that for me?
Best Regards,
Message 38 of 68
Alfred.DeFlaminis
Hello @irishman_team_kilber,
Do you have a file you can share with the issue you are talking about in your previous post?  I can log it if I can repro.  Thanks!
Best Regards,
Message 39 of 68
Sorry i deleted the wall and recreated it and it seems to fix the issue,
Faulting application name: 3dsmax.exe, version: 9.2.0.114, time stamp: 0x4637ce7f
Faulting module name: ntdll.dll, version: 6.1.7601.23539, time stamp: 0x57c997df
Exception code: 0xc0000374
Fault offset: 0x000ce843
Faulting process id: 0x1f3c
Faulting application start time: 0x01d353923ce7906c
Faulting application path: C:\Program Files (x86)\Autodesk\3ds Max 9\3dsmax.exe
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id: 2d43fb30-bf89-11e7-a303-902b3438e12e
Message 40 of 68
Chri688m
Alright @Alfred.DeFlaminis, so i un-parented the objects divided and parented the objects into the walls again, and it worked..
This leads me to another question...
Can i set the default divisions in AEC to be a certain amount per. centimeter or meter. // or just set it to always be 10 divisions as default?
In terms that would solve the entire issue about thise divisions.. ie. making AEC alot better! Smiley Surprised
