AEC Doors Problem
AEC Doors Problem
mbvisualsretaildesign
AEC Doors Problem
Whenever I try to place a door, I start with left to right insertion points and then modify the dimensions.  However, the door always comes in at a rotated angle, usually 90 degrees. I can correct thisof course, however, with this process a void is not being cut into the wall.  What am I doing wrong?
MB Visuals Design
joaquim.moral
Hi @mbvisualsretaildesign
Thank you for participating in the Autodesk Community!
To better assist you, could you please share a screenshot of what you're trying to do? This will help the community understand your question more clearly.
Thanks!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager - EMEA / LATAM and Media & Entertainment lead
leeminardi
Note the snap settings and mouse use highlighted in the video at this thread.
https://forums.autodesk.com/t5/3ds-max-modeling-forum/door-not-cutting-through-wall-again/td-p/84225...
lee.minardi
joaquim.moral
Hi @mbvisualsretaildesign,
Did the video provided by @leeminardi answer your question?
If so, please use Accept Solution so that others may find this in the future.
If not, let us know so we can keep helping you.
Thank you very much!
Joaquim Moral
The video was helpful, however, that process doesn't work for me. I've provided a screenshot showing how the sliding window looks when placed into a wall.  The other screenshot shows how a door cuts into the wall but always comes in rotated even when using snaps. I keep having to select the object and rotate it to the correct angle. Frustrating.
M B Visuals Design
