Announcements
3dsmax missing command pannel
Hi Guys,
I have a problem with my 3dsmax, my command pannel on the right hand side is missing.
I uninstall and install the software again but still... nothing!
I checked every topic and tutorial but I can't have it back.
What can I do??
miledrizk
Assuming you did all you can, including right clicking the toolbar and choosing
Command panel, plus all the install and uninstall, well you can reset your user settings:
Close max and go to: C:\Users\YouUserName\AppData\Local\Autodesk\3dsMax\20xx - xxbit
And rename the folder called ENU to something else like ENU.old and reopen Max
Note: Appdata is a hidden folder so you need to enable show hidden files and folders from the
Control Panel
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
