3dsmax 2019 script controller pop up on start up
Hi there,
Appreciate if anyone could help with this issue that I have been facing.
The script controller dialogs pop up whenever I load a scene in 3dsmax. Prior to this, I created a vehicle and loaded into the Private Resource Kit in Civil View. However, I deleted the vehicle after I realised it is not what I wanted. Then I close the scene and open up the same scene again. The script controller dialogs will pop up upon loading the scene as per the screenshot below.
This is annoying as I have to manually close all the pop up boxes 1 by 1 and there doesn't seem to be any solution on the forum.
I'd appreciate if anyone could assist here to solve this issue.
Thanks.
So no one and not even the Autodesk technical specialists can answer to this? Why are we paying so much for this software that has so many issues and bugs?
jibijib
A script is running when you open the scene.
It doesn't do this when you open max?
Can you try opening the scene, and then selecting the mesh and 'save selected', then create a completely new scene and then merge the scene you saved out into the new one.
Don't get too let down by no responses, it is kind of slow in here.
Also check the 3d Studio Max section on Reddit.
Thanks for the response.
I've tried your method and it worked. Many thanks!
Thanks for sharing on reddit. I'll be sure to check it out.
