3ds max vewport Flashes off and On
Message 1 of 10
Hello There!
Can anyone tell me how to stop the viewport stop flashing the image off and on when working or opening another viewport? For Example: if I open the side viewport the top viewport disappear and a few seconds later it will appear.
Thank You.
Replies (9)
Message 2 of 10
Hi, i suspect that you have adaptive degradation "on". You have a button just below the viewport (a transparent cube) to swich this option "on" or "off".
Explanations on Adaptive Degradation: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMa...
If you suspect that this is an hardware problem, please provide your full system specs.
Message 3 of 10
kgokhangurbuz
This may be caused by your Graphics Card or its drivers, or your Graphics mode of 3ds Max.
Please try these (not all at once please)
-Update your Graphics Card Drivers (also please check your DirectX version, update if necessary or Repair it by reinstalling it)
-Go to Customize > Configure Driver > Choose anything different then Nitrous (preferably Direct3D) and Restart 3ds Max
These two options will solve your problem most probably, but please let me know if your problem still continues.
Best regards;
Message 4 of 10
Thank You for he info, All my drivers are up to date and what I got is what the system recommend with 3DX 11. My video card is an Nvidia GT 730 DDR5 2GB Ram. The Version of 3ds Max that I got is 2016 and it say Nitrous Direct 3D 11. and still flash off one viewport when I click on another to do some work. WEIRD!!!!!!!!
Message 5 of 10
OK I see it is on and it don,t want to turn off for some reason. Thanks.
Message 6 of 10
Thanks , It works I adjust the settings.
Message 7 of 10
kgokhangurbuz
What kind of an adjusment did you use? Some information may help other people who are experiencing this problem.
Best regards;
Message 8 of 10
Sorry about that I have a little issue with my network and I forgot to said what I did, OK! I click on the (+) sign on the viewport and click Configure Viewport - Display Performance and under Adavtive Gradiation where it said Maintain Frame Per SecondI just lower the frames from 10 to 5 and it's stop flashing the viewports on and off.
Message 9 of 10
I still got the same problem but now is when I'm Texturing and rendering I even lost some part of the model in the texturing box when I was going to add the engine. It slow, Sluggish and even comes out on top "NOT Responding" and sometimes it takes a while to open a scene.
Thank You.
Message 10 of 10
kgokhangurbuz
is it possible for you to try the same scene with another computer which has different cpu or gpu?
You can share your scene with me (if you don't want it to be open to public, feel free to send me a private message), so i can try and test it to see if the .max file is damaged or it is a hardware / driver issue?
(make sure that you save your file as Archive - File > Save As > Archive, and make sure it's saved for 3ds Max 2014)
Best regards;
