3ds max to Sketchup - Reduce file size
Message 1 of 12
I need your help ASAP.
So I´ve made a chair on 3ds max and now i'm trying to export to sketchup. I've used a lot of different options to do that  but the problem continues the same. No matter what I do my skecthup file is always too big to later share on sketchup warehouse. I have 2 max files of this chair with small differences. Both sizes with 10mb and 31mb. I've managed to compress both to 1,02mb and 8,26MB (on 3dsmax). I've already used the following methods:
-SimLab (converts directly to sketchup file- Result- Sizes on skp: 20,05 MB and 47,7MB...)
-Blender (first converted an obj in 3dsmax, imported to Blender then exported a 3ds file to import again in sketchup)
If I save only on 3ds it gets to this sizes: 2,48MB and 8,45MB. BUT then it shows all geometry that I have to Soften/Smooth Edges. Once I click "save"...boom...my files goes again to 20,05MB and 47,7MB. This happens no matter the strategy.
-CleanUp or Purge Unesed (with TT-Lib.2.12) - just doesn't do anything....no alteration at all
- I've also tried with SimLab Composer but my computer got too slow so I went to the other methods above...
So does anyone knows any steps to reduce a Sketchup file imported from 3dsmax? Many thanks!
Marcia
Replies (11)
Message 2 of 12
rendermaster
i normally go with 3ds max to autocad to sketchup
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 12
Thank you! but it didn't work. Just tryied it. Exported from studio max to an DWG (13MB). It got even bigger (55 MB) when I saved in SKP. Before I had 47MB.
Many thanks
Message 4 of 12
rendermaster
sorry to hear that... how about posting the file in here for us to better check the condition of your model....
Message 5 of 12
I took your advice and apload one of the chairs (biggest file). It is in sketchup and max format. Hope someone can help me. Thanks.
Message 6 of 12
hagen.deloss
@Anonymous
I put a [Optimize] modifier onto the bolts along the rim of the chair and it dropped the file size by 2mb, i would start there!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 7 of 12
hagen.deloss
@Anonymous
Also, make sure to collapse your modifier stack before importing, this could add to file size! Right click on the modifiers and select [Collapse all] before export.
Hagen Deloss
Message 8 of 12
rendermaster
this what i have done so far.....
Chair.skp - original files
Chair_V2 - 3ds max(button was modified with Multires Modifier to 50%) to Autocad to Sketchup (applied smooth)
Chair_V3 - 3ds max(button was modified with Multires Modifier to 50%) to FBX to Sketchup (applied smooth)
Message 9 of 12
I just did what you said and it helped a lot! My chair size just dropped to 8,31MB. I want to reduce even more. Do you have any idea how to do that? Thanks!
Message 10 of 12
I used Multires and autocad to sketchup but for me it only dropped 2MB... I must be doing something wrong...
Thanks a lot. You guys are really helping me
Message 11 of 12
By the way,
I used both answers on the other File "Chair 2" but none of them worked. The file got bigger...
I thought maybe MultiRes would work on this one (now it is with two lines around the chair) but wrong. My max file stays small (1,02MB) but on sketchup is always big (20,5MB).Do you know any technique to reduce this new file i've just attached?
Thanks!
Message 12 of 12
rendermaster
- the model has a dense polygon especially the button lining which is not practical to be that way because of its size. it causes a lot of numbers of faces and polygons giving SketchUp a hard away preserving the surface shape while sacrificing the file size.  anyhow:
1.  if you wish to decrease more of the file size, you need to remodel those button using just the half sphere with less side ( say 6 or 8 side) - this will reduce more of the file size. of about 30-40 percent (approx)
2.  since the model is symmetrical, you can delete half of it, then export it in sketchup. make a component in  then mirror it
