3DS Max Skin Modifier Bone Selecting
Couch_Potatoh
Couch_Potatoh
This isn't a life breaking thing, but extremely annoying and I can't figure out what I did this time.
When I go to add bones using the Skin Modifier, it will automatically select every bone that's a child to the bone I click on. I cannot select just one. The only way I can select one Bone is to isolate that one bone and the object I want it skinned to, then add it like that.
Is there some setting I messed with by accident? I can't figure this out...
Thanks!
Using 3DS Max 2016 SP4
dominique.bouthillette
Autodesk Support
Autodesk Support
Hi @Couch_Potatoh, I'd like to help with this issue. 😃
Could you perhaps share the file you're working with so I might have a look? Or include a Screencast video of the issue?
I have tried adding bones to a new Skin Modifier and cannot seem to reproduce the issue on my end. I'd be happy to see what might be happening in the file for you though.
If the scene is proprietary, you can upload it to a private Box folder here.
Thanks so much!
Dominique
Please Accept as Solution if a reply has helped resolved the issue or answered your question, to help others in the community.
Kindest regards,
Dominique Bouthillette
Principal Specialist, Industry Support & Escalation
Entertainment & Media Solutions
Alfred.DeFlaminis
Hello @Couch_Potatoh,
I just wanted to follow up here, any progress on this issue?  Are you using the scene explorer or the old list view for selections?
If scene explorer, make sure you don't have 'select children' checked on the Select menu in the upper left, that might do what you are seeing here.  In the old list view, that is called "Select Subtree".  Could that be what is causing this?  Thanks for the information!
Best Regards,
Couch_Potatoh
Yep, that was it. Select Children was in use. I assume I hit ctrl+c since it's the hotkey. I just couldn't figure it out at all.. Thank you!
Alfred.DeFlaminis
