3DS Max Saving of the scene without permission
Message 1 of 8
When I want to quit the 3ds Max-scene without saving and I push the button "don't save" it still save the scene.
strange... don't no why....
 @Anonymous
Your post subject line has been edited by @hagen.deloss: Saving of the scene without permission
Replies (7)
Message 2 of 8
jeff
Just a guess:
In preferences > files, try turning off "autosave"
Max since 1992 (3d Studio) · Win 10-64 · Wintel workstation · 64 GB RAM · nVidia Quadro RTX 4000 · BB render garden via Deadline
Message 3 of 8
hagen.deloss
Hello @Anonymous,
it looks like you are visiting as a new member to the 3DS Max forum. I want to extend a warm welcome to the Autodesk Community!
Have you checked your save settings to see if you have autosave turned on? That can be found under
Customize > Preferences > Files tab. Under Auto Backup, check or uncheck the Enable check box.
If that doesn't do the trick, it may be helpful to reset 3DS Max to its default settings, step by step instructions to do so can be found here.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 4 of 8
hagen.deloss
Hello @Anonymous
I wanted to check back and see if my post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hagen Deloss
Message 5 of 8
Hey Hagen
To change the Autosave-Settings was not a solution. But to reset Max and delete the ENU-files was the trick. Now it works again. Thanks for your help.
But i still can not explain me why it happened from one day to a other on all of our workstations in our office without making a update of Max. The only thing we changed was a windows update in the last Week.
kind regards
Message 6 of 8
hagen.deloss
@Anonymous
I'm super happy that it worked, yaaaaay! 😄 Thanks for accepting the response to your post as a solution so that others can benefit from the information.
It may be worth looking into why the windows update changed your save settings, I found a similar thread from a few months ago that could offer some insight. Feel free to let me know if you have any questions or concerns!
Hagen Deloss
Message 7 of 8
I had the same problem and found it to be a corrupt ALC script that automatically launches on startup in each file  and infects the scene in strange ways. I resolved it by adding 'ALC fixup' and 'CRP fixup' scripts in the 3ds max startup folder to remove the corrupted scripts when 3ds max is launched.
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Scene-...
Message 8 of 8
It worked!! thanks man, i followed the instructions of your link and it is solved. Just installing that plugin and click on Clean when opens the file, it magically fix the issues. Thanks!
