Hey there,
after closing my 3ds max, the viewport settings and my units-setup is gone, when I start it again. Can I set my settings as standard load preset anywhere?
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous and welcome to the community,
What you can do it set up Max the way you want it, then save the empty scene into the default folder (\scenes) as "MaxStart.max". Then when Max opens every time, it will load that file which then has all your settings. Can you please try that for me?
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
