Hello everyone!
I got a problem as i was working on 3ds Max. I made this chair design
But when i am trying to render it it is showing a black window in rendering box. Not only this file but for other files also . what can be the problem? black blank screen's screen shot is down below.
if anyone knows please tell me the solution. Thank you !
Solved by rterry. Go to Solution.
also, look at the top left corner of your rendered frame (the 2nd pic), the Area to Render is on Selected, try putting it back to View
(also, I can't quite tell by the scrollbars but make sure the viewing window is large enough)
ok, i don't have 2015...and with fading memory...how about turn ON Final Gather ?
also try render from Perspective instead of Ortho...clutching at straws here...
if you want, in a file that's not working...drag out a Teapot...see if that renders...if it doesn't, delete all your main objects, leave the Teapot there and save it as a Test file, then upload it.
toggle the "Display Alpha Channel" button in the rendered frame buffer window. its the half black/half white circle icon. if you see nothing when you toggle that on, then nothing is likely rendering at all. if you see something i.e. a white version of your chair, then it could be your exposure settings. Open the Environment and Effects dialog and check. Do you have mr photographic exposure control selected?
-=Rob
Thanks for replying again. I am not able to render any file. Even a new file . i tried rendering other 3ds max files that i ave . but none of it is working. I guess problem is in 3ds max settings. if i upload my file here. it wont be helpful i guess because problem is wit 3ds max settings, not with file
Hello, Thank you for replying . Well i selected 'mr photographic exposure control' but it didn't help. It was still black screen. Actually when i opened the dialog box nothing was selected. First i selected 'mr photographic exposure control' , it didnt work but then i selected 'Automatic exposure control' and it rendered it. can you tell me what exactly the problem is? i am attaching two pictures along with it . even after rendering it with 'Automatic exposure control' it showed a dialog box which i don't understand.
haha...don't tell me you are displacing at an enormous setting....ie...your geo is blown up so big...it envelops the whole known universe...so the guy that built the universe and then said let there be light....well...he's looking very dejected right now...
Try turning OFF displacement...see what happens...
actually...scratch all above...I dunno what I was smokin'...the Teapot is right there !!!
OK, it looks like were getting somewhere...don't sweat those error messages at the moment. Since you're using mental ray, lets make mental ray happy and verify some things. try this--in that teapot scene or better yet a new scene, create a teapot and then add a photometric light to the scene, in this case, add a daylight system.
after you place your daylight system, you will see dialog box open that looks like this:
just click yes.
Then open the exposure dialog again and change settings to appear like below image.
Make sure mr Photographic Exposure Control is selected (red box)
do a quick Render Preview (yellow box) should render the teapot and have a nice blue gradient sky in background
play with presets and EV (exposure value) (green box) for daylight will be between 13-15
If above preview looks good, go do a render and make sure the settings are like this:In particular make sure the render view is set to the viewport your teapot is visible in. i.e perspective, not top view, etc.
finally, render the scene
if still nothing renders or if it appears black, verify you were rendering correct viewport and click on the alpha toggle in the frame buffer window this will tell us if the geometry is visible to the camera by displaying a pure solid white teapot on a black background.
let us know how it comes out.
-=Rob
Hello @Anonymous and welcome to the community,
I wanted to see if your issue is resolved here and if not, help in any way possible. Did the helpful posts by @rterry and @Anonymous end up resolving this for you? If not, I'd love to help out.
It's always best if I can check a file, most settings for the scene are saved in the scene. If you'd like I can create a private folder for you and investigate there, just say the word. I do want to see this issue resolved for you, thanks!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
hello sir,
i am also suffering with this problems, i am trying to render its showing a black window in rendering box. Not only this file but for other files also . how to solve this problem.
Did you try the things in this thread? Can you attach a simple scene with this problem, please?
Best Regards,
I was able to fix my problem with the advice given here. I used the daylight system with the advised settings but used an exposure value of 12 and cranked up the whitepoint to 15000 kelvin to reduce the blue color
Hello everyone, thank you for this very helpful thread!
I add a similar problem and I was able to solve it. However, I also work with - Cebas final render, and with this render
I still have a black image. did anyone encountered with this before?
thank you!
Gali
Thanks for your question! In general, if you render a scene and it comes up completely black, that usually means:
Since Final Render is manufactured by Cebas Software and not Autodesk, could you please contact their technical support if you're having issues with their renderer, and let us know what they say?
Please let us know, and thanks!
