3ds max render help for beginner: vray not rendering properly
I am a beginner in 3ds max. I am using the 2016 version.
I have created an interior scene which i modeled in Sketchup and imported to max. I have watched many tutorials for vray and camera settings and seemed to have done everything right. Here's the thing; I get a black screen in the render preview. I am using a vray sun and lights. adptive image sampler, and irradiance map as the primary engine. I dont know how to fix this.
Also, for checking, i opened a new file tried a basic teapot, plane, vray light and physical camera. But the result is also an almost black screen with a hint of the color of the teapot.
Please help and advice!!
rendermaster
your file is doing fine...just adjust the intensity...and take out exposure
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Which intensity? light or anything else?
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I'd like to help with this issue regarding black renders.  Your scene does render right off the bat when I test it.  I wonder if you are not getting a license for Vray, which is causing it to render black.  If you press F10, go to the Vray tab and open Authorization... what does it say there?
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
