3ds max path deform 'move to path' button missing
RadioRahim
RadioRahim
As seen in this video there is a feature I want to learn to use, but it seems absent in my version. Here is the video:
https://youtu.be/0w795ghYOLI?t=239
here is the screengrab from the video                                 here is mine.
man is this site ever difficult to insert images in the right place! Anyways.. you can see from both images that one has the button and one that does not. I am using 3dsMax 2017 (im not sure which version is being used in the video)
Can anyone tell me where this feature went, or how I might go about accomplishing the same thing in the video using 3dsMax 2017?
Cheers!
RadioRahim
Also it seems that the version I am using behaves differently than what I am seeing in other people's videos.. For example, when I create a line, and use this as the chosen path for the path deform, instead of my cylinder following the path I chose, it uses some new path called Gizmo. Please see attached video:
https://youtu.be/d8gdke6KJBA
I am not sure what I am missing here, but any insight is appreciated.
Thanks!
domo.spaji
That's the Path Deform WSM (world space mod.)
RadioRahim
ohhh I was comparing the wrong things! WOrld and OBject..
Its working well now, thank you so much!
mrigankdelhi
 hi i have a problem can anyone pls help
i have animated an object in 3ds max using path deform WSM now i want the object to retain its animation but i want to remove the path so that i can move or export the object is there anyway to do it?
