3ds max file size unreasonably large - slow open and save...
Message 1 of 25
I had the same problem with 3ds max 2012 and now with 2013. I tried on several computers in my company.
For example, I have an empty scene. I merge an object from another (big) 3ds max scene - 100 polygons (chamefered box). Now my new scene with one objects in 120 megabytes big. I delete the object and save, and an empty scene is 119.8 megabytes big...
What seems to be problem here. In time, after lot of combinations, merging, modeling and adding, many my scenes are "infected" with large file size, and I dont know what to do about it. We almost missed some deadlines for very important clients due to this.
Please help. I am not the only one with this problem.
Replies (24)
Message 2 of 25
Steve_Curley
http://area.autodesk.com/blogs/maxstation/n103_some_other_variations_of_files_that_are_too_large_or_...
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 25
After more than a year, finally an answer:
http://area.autodesk.com/blogs/maxstation/n49_overly_large_max_files_or_scenes_that_take_up_a_lot_of...
I will "clean" hundreds of my scenes now...
Oh, we posted at the same time.
Thanks 🙂 This made my whole year 🙂
Message 4 of 25
spacefrog_
For people not constantly checking scriptspot:
A nice script has been released recently called "Cleaner".It should help you to automatically clean some of the bogus file-bloating issues from your scenes via button click...
http://www.scriptspot.com/3ds-max/scripts/cleaner
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Message 5 of 25
Cleaner didnt help me (one version didn work, and the other was too slow), but this did, with at least 30 HUGE scenes since i started cleaning them yesterday:
i pasted and run this into maxscript listener (from this thread http://area.autodesk.com/blogs/maxstation/n49_overly_large_max_files_or_scenes_that_take_up_a_lot_of...
t=trackviewnodes;n=t;deleteTrackViewController t n.controller;gc()
my life has changed since.
Message 6 of 25
spacefrog_
Looks like Cleaner is'nt too optimized doing it's stuff than...
You might give the author a hint how he could clean the note tracks with this line in a more optimal way...
Josef Wienerroither
Message 7 of 25
sergezinskiy
Community Visitor
Community Visitor
Any ideas why the link doesn't work?
Message 8 of 25
hagen.deloss
Hi @sergezinskiy
Thanks for bringing your question to the forums, it looks like you are visiting as a new member to the 3DS Max forum. I want to extend a warm welcome to the Autodesk Community!
It may be that the link is dead, maybe try this scene cleaner, or this garbage collection function.
Let me know if you need any other help!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 9 of 25
what is the name of the blog that you choose
because i opened the link  above and found alot of blogs
Message 10 of 25
ViperAleks
If you use V-Ray, there is a bug somewhere with the data leak after merging objects into the scene. I have found a work around. In the problem file you have to save V-Ray render settings to the renderpressets file (.rps) and than load render presets from this file. It could be another preset file though. After you loaded render presets, save your .max file and you will notice that the file size is decreased.
Message 11 of 25
vigneshvaran
Fix As of 24-3-2021
These 2 Scrips worked for me if anyone having the same problem with big file size
https://3dbrute.com/purge-and-clean-file-3dsmax-reduce-3dsmax-file-size/
Message 12 of 25
mujahid798
Community Visitor
Community Visitor
Thanks a lot.
Message 13 of 25
fatima.adlipour
Community Visitor
Community Visitor
Hello. I really do not know how to thank you dear friend.
You solved my problem easily
May God give you the best
hope you always get the best my friend
god bless you.. thanks million million times....🙂
Message 14 of 25
infoQER9N
Community Visitor
Community Visitor
Million thanks for your help. It works well.
My file was 3.5GB reduced to 2.4GB. It works better now. I ran the scripts again, but in 2nd time it gives an error message.
Is there any way to decrease the file volume more?
Thanks again for your help.
Message 15 of 25
vigneshvaran
If you have the latest Max 2023, enable compress on save and it should reduce the file size even further (Saving takes couple of seconds more BTW)
Message 16 of 25
gandhics
Message 17 of 25
mrhoangthanh
Community Visitor
Community Visitor
Can you please show your solving issue again ?
This link is unavaiable to see "http://area.autodesk.com/blogs/maxstation/n103_some_other_variations_of_files_that_are_too_large_or_..."
I got issue like your past. My max file be bigger than 1.4gb, and i can not open or merge my max file anymore
Message 18 of 25
smallmax3D
Community Visitor
Community Visitor
Thank you
I am grateful to you 🙏
Message 19 of 25
anandjparikh
Observer
Observer
link doesnt open
Message 20 of 25
darawork
The link above is dead. Please visit the link for 'Scene Cleaner' provided by Hagen.deloss:
https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-file-size-unreasonably-large-slow-open-and-save...
Or alternatively here is a direct link: https://www.scriptspot.com/3ds-max/scripts/cleaner
(Individual Maxscript code solely for cleaning Notetracks, please read description):
struct s
	tTooltip = "3ds Max tends to automaticly save notetracks in your scenes that are comments for animationtracks.
However these notetracks can become quite numerous and dramatically increase the size of your scene and make saving process extremly slow.
So it is a good idea to keep an eye on these automaticly created notetracks and clean them from time to time.
Remember that you will import notetracks from other files if you are using xrefs.
Cleaning just the scene doesn't solve the problem, you got to clean the xref aswell or you will import the notetracks everytime you load the xref.
	fn count =
		try (numNoteTracks TrackViewNodes.Max_MotionClip_Manager) catch ("")
	fn clean =
		try
			trackViewNodes[#Max_MotionClip_Manager].track = copy trackViewNodes[#Max_MotionClip_Manager].track
			gc()
		catch()
Always save a backup of your scene file, just in case, when using 3rd party scripts.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
