3ds Max crashing when starup, script controller error.
Hi. I was suggested to uninstall 3dsmax 2018 by 'MicrosoftProgram_Install_and_Uninstall.meta' and reinstall it but it doesn't work even though I also install the 3dsmax security tool too. This situation happened before but it fixes after I install the security tool... For now, my 3dsmax still closes immediately after it pops up the window shown in the image above. Should I delete any files in scripts>startup or uninstall any program besides 3dsmax 2018 like MAXtoA, Material Library 2018, or others before I reinstall?
DanielCantin
I think this support article might explain and have a solution for your issue:
"Script Controller" error, scene file crashes, and corrupt scene data due to third-party MAXScript (...
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
Hi Cantind thanks for reply. Based the solution in the article that you suggested, it not works for my issue. I can't run the 3dsmax which means I can't open the Command Panel to detect "ALC2". I also try to install the Security Tools 1.3.0 but it still crashing.
