How to select back polygons after update ???
Previously, I could easily select a polygon behind another by double-clicking the left mouse button. After updating, now when double-clicking on a polygon, it selects all polygons along the loop, and not the polygon that is behind it. It drives me crazy and makes editing polygons inside the object inconvenient.
This is an update error, I found out about this in the update description. I am giving up on 3ds max and switching to Blender. 0 support on the forum. 0 support from autodesk. The high cost of the program for untested and unstable updates, without support. It takes a long time to release a fix or hotfix.
Issue: If a vertex, edge, or face point overlaps with another when working with edit poly/editable poly, only the closest point will be picked when you click on it. You will not be able to cycle through the overlapping points by clicking in the same spot, as you normally would. Workaround: Rotate the view and click on the desired point. MAXX-58907
That's awesome, I wish I came up with that simple workaround 😀. Other selection methods like loop polygons are also changed but I managed to find the answer somewthere in Autodesk's forums. This one is a constant issue now. I hope Autodesk will start listening to users and make Max great again 😀. For me, the only thing stopping me from switching are plugins and models that are Max oriented.
