Hello sir my name is sandeep iam a 3d designer in dubai 5 day before iam updated my 3ds max 2016 to 17 performance and working is awesome but iam in a trouble there is no vray avilable for 2017 iam using V-ray Adv 3.30.05 Orginal version when vray for 3ds max 2017 will availabe please help me .
V-Ray updates for Max are released by Chaos Group, the developer of V-Ray as soon as they get them ready. They take a month or two sometimes before they release them. Autodesk has no control over it.
As excited as I get about each new arrival of Max, over the years I've resorted to waiting 3-months to install it so that the needed 3rd-party updates are available. If I install it right away I'm both tempted by it and frustrated by it. I can play with the new features but not use it for production. So I just wait.
The slowest vendor to update drivers is 3DConnexion. It takes them forever to release drivers for the Space Pilot and other navigating devices. I know there is a beta program for Max. I can't understand why these preferred vendors can't be given nearly final versions of Max a few months ahead of time so they can go ahead and update their drivers. That just seems to make sense. However, for some reason, it does not occur.
We feel your pain brother.... 🙂
Rob Holmes
Hi sandeep,
V-Ray 3.4 for 3ds Max 2017 is now available for download.
V-Ray 3.4 adds support for 3ds Max 2017 including initial support for the new Physical Material and HiDPI scaling of the V-Ray Frame Buffer. V-Ray RT now supports MultiTile and ColorMap.
Thanks and Regards
Karan Singh
Hi karan,
Thanku for your Information iam Already got this working good,but vray cam is missing now am using plugin for crating camera idont familiar with physical camera with vray if you know about any tutorial for that please refer me also.
thank you
sandeep
HI,
You can still create the vray cam; type this in your MAxScript Listener: vrayCreateVRayPhysicalCamera()
Ihno Oetjen
Senior 3D Artist
Whishlist:
Calculator for all Parameter inputs.
Random seed for adv. Wood.
Curvature map node.
Thanku sir
the script is amazing easy to create camera thank you so much . iam facing another problem in max 2017 my camera and vray plane showing small icon
iam attaching the image so you can easy to identify the problem iam using vray 3.4
Please give me a solution
thanks and Regards
sandeep
Hm... I don't know, you should post this in the Chaos Group forum or send a mail to their support.
Usually you get an answer within one day.
Ihno Oetjen
Senior 3D Artist
Whishlist:
Curvature map node.
I "guess" you're not asking for a pirate copy in the offical AD Forum.........
You can simply download it from the Chaos Group webside... Buy a licence if you don't have one already.
And than you can simply download the version for 2017:
https://accounts.chaosgroup.com/?return_to=https://download.chaosgroup.com/login?original_url=aHR0cH...
Ihno Oetjen
Senior 3D Artist
Whishlist:
Curvature map node.
LOL now that would be funny! No I have a vray liscence. When i go to Chaos site the only download available for max 2016 and 2017 are demo versions. Chaos is now telling me that there records show that I have only a v-ray 2.0 license. I was told at time of purchase that I would be able to get upgrades as max upgraded. Now I am concerned that I laid out $1000,00 for software i have never used.
Haha, ok I'm sorry. Your question sounded pretty odd to me.
But you should use it! Vray is a monster compared with 3ds max native renderes. Especially the 3.x.
They charge 300€ for a workstation licence ubgrade. Don't know the dollar price though.
But if you have a render farm you'd have to buy rendernode licenses.
But again, Vray is worth every penny imo.
Ihno Oetjen
Senior 3D Artist
Whishlist:
Curvature map node.
Thanks I will look into it. So looks like i may need to shell out another 319 bucks. I need to make myself use vray. I just always thought that MR or quicksilver would work i just needed to know more of what i was doing.
Just as a side note I take a lot of pride of the fact that out of the $10,000.00 worth of software I have and use I have none that is pirated. I almost wish Chaos had a free distribution and only take royalties as you make money from the use of the product. Similar to the way Unreal is doing it.
Thanks for you input
Chaos got back with me and said that I would need to upgrade to 3.0 Have they made leaps and bounds since 2.0? I downloaded phoenixfd vray 30. demo and it looks pretty cool but none of my render engines will render any of it. Will vray 3.4 come with this?
They added countless improvements and features since 2.0.
markr schrieb:
Chaos got back with me and said that I would need to upgrade to 3.0 Have they made leaps and bounds since 2.0? Like can you do liquids, smoke, fire and better particles? Things like that?
Some of the most important:
You use MR, so you have to fiddle with all the sample parameters in the materials and lights. In Vray it was called subdivisions.
No need for that anymore, it does that job automatically. Which saves alot(!!!) of time.
Brute Force GI is way quicker now.
Progressive rendering,
Which lets you see the whole image from the begining of the rendering (much like Iray)
Denoiser:
A Render Element which helps to reduce the rendertime by denoising the final image.
3.5 is right around the corner and it adds IPR Rendering so you can use the CPU version of vray like active shade.
Also 3.5 will have an adaptive lights option which lets you render scenes with hundreds of lights a fraction of the time required now.
For fluids they have another plugin which is quite understandable because it has nothing to do with rendering.
So you'd need to buy it seperately. Take a look at the trailer:
https://www.youtube.com/watch?v=ew5-7lwc9GM
It is alot of fun and eats alot of my sparetime
Vray 3.x will works perfectly with phoenix.
But fluits are hard to use in production because of the time they need to simulate. This is a problem in every fluid simulator not just Phoenix.
Ihno Oetjen
Senior 3D Artist
Whishlist:
Curvature map node.
Vray is great, hands down. 3.0 is much better than 2.0, and with 3.4 you don't even have to know much about it to get good renders. Nothing bad to say about Chaosgroup or Vray, great stuff!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
well I must be sold on vray. I just upgraded. lol
thanks for all you input!
Hello @Anonymous,
Given all of our discussions about rendering and lighting over the past few months, I think you'll be happy. The support forums for Chaosgroup are pretty great as well.
Best Regards,
Glad to hear it @Anonymous!
Best Regards,
