Hello @Anonymous,
I checked your crash logs and two of your crashes are from bugs that were fixed in Sp1 and Sp2. Which Service pack are you currently on? This is the area I can help the most.
Do you have more than one GPU in your system? (I.E.- are you using both the quadro and the 1070?) If you are, you might be having power issues. Both of those cards plus all the other hardware might be too much, but hard to say.
There are some error messages in the event viewer logs that might point toward system problems but it's hard to tell with some of them because I am not much of a hardware fixit specialist. I can list what I'm seeing though and maybe it can help you look further. I have to admit harware isn't my specialty and I can't provide that much help on it, but I can list the problems I'm seeing. I can't say for sure if these errors are important or not, just that they caught my eye. You have quite a few errors related to the following:
Kernal PnP (plug and play). Points toward a device on your system that isn't fully compatible with W10. These driver issues can cause all sorts of weird problems, so I would look to find out what this is referring to. If the Kingston reference is RAM, you might need to check your motherboard white paper to make sure they are compatible with this much RAM/chips in the current cofiguration. I'm only seeing 2 kingston chips on there at all, so maybe a memory compatibility problem?)
The driver \Driver\WudfRd failed to load for the device SWD\WPDBUSENUM\_??_USBSTOR#Disk&Ven_Kingston&Prod_DataTraveler_111&Rev_PMAP#070729EA32D7D043&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}.
The driver \Driver\WudfRd failed to load for the device USB\VID_05AC&PID_12A8\2021ac84b0158e901f4f1c76806c112421beee12.
Nvidia drivers and crashing or NVIDIA related;
Display driver nvlddmkm stopped responding and has successfully recovered.
NvAPI_GPU_GetBoardInfo error code=-1
The Nvidia Quadro driver detected high GPU memory usage. This will impact application performance. (Is the quadro still in the machine? Weird code.)
Faulting application name: NVDisplay.Container.exe, version: 1.0.0.0, time stamp: 0x584d90c8
Faulting module name: NvXDCore.dll_unloaded, version: 8.17.13.7633, time stamp: 0x584d9d8d
Exception code: 0xc0000005
Fault offset: 0x000000000004b8c0
Faulting process id: 0x540
Faulting application start time: 0x01d25f0b46a45f6d
Faulting application path: C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
Faulting module path: NvXDCore.dll
Report Id: 06abf63f-42ac-40a7-85d3-b48e416572ec
Faulting package full name:
Faulting package-relative application ID:
Kernal Power: (lots of these, hard to say if it's important.)
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
3ds Max: (Interesting that the faulting module and path is empty.)
The program 3dsmax.exe version 19.0.1072.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel. (Can you please check this to see what it says?)
Process ID: 24f0
Start Time: 01d25a2a54778025
Termination Time: 17
Application Path: C:\Program Files\Autodesk\3ds Max 2017\3dsmax.exe
Report Id: 34d168d8-c622-11e6-b139-1c1b0d05e22b
Faulting application name: 3dsmax.exe, version: 19.3.533.0, time stamp: 0x57cf64b2
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Fault offset: 0x0000000035f65ba0
Faulting process id: 0xebc
Faulting application start time: 0x01d25c258c5b5c81
Faulting application path: C:\Program Files\Autodesk\3ds Max 2017\3dsmax.exe
Faulting module path: unknown
Report Id: 0ed4d7f6-c70b-4461-a782-9e9e9e8169c4
Corsair Link 4: (Google indicates lots of problems with this, whatever it is. It's crashing with .Net, which may point toward .Net problems? I am unfamiliar.)
Application: CorsairLink4.Service.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at CPUIDSDK.Close()
at CorsairLink4.Module.Dram.DramComponent.Dispose()
at CorsairLink4.Service.Service.DevicesMonitor.Dispose()
at CorsairLink4.Service.WindowsService.Dispose(Boolean)
at System.ComponentModel.Component.Dispose()
at System.ServiceProcess.ServiceBase.Run(System.ServiceProcess.ServiceBase[])
at System.ServiceProcess.ServiceBase.Run(System.ServiceProcess.ServiceBase)
at CorsairLink4.Service.Program.Main(System.String[])
I cannot help much with the hardware and driver issues but I wanted to point out what I was seeing. You might check if you have any firmware updates to your hardware, but I cannot officially recommend to anyone that they flash their devices. This is about all I can do regarding hardware, but if you need any help with installing the Max service packs or anything I am happy to help. I am interested to see what happens here.
Best Regards,
