Solved by jon.bell. Go to Solution.
To answer both your questions: the Arch & Design templates issue and the linking/grouping scale issue have been logged and our developers are working on them.
Although I can't state for certainty when a fix might be available for these, there is a workaround for the Arch & Design presets issue. Here is a direct link to a quick MaxScript fix, courtesy of Area Forums member SpaceFrog:
http://www.frogsinspace.at/?download=3ds%20Max%202016%20SP2%20-%20AD%20Templates%20Fix
To implement it, open 3ds max 2016, SP2, then drag and drop the script into any of your viewports.
After installation, close, then restart 3ds max. (For best results, you should be running 3ds max and the script as an Administrator.)
Below is the link to the original Area thread discussing this fix (this is the second page of the discussion):
I hope this information helps, and when there are fixes for any other issues introduced by SP2 we'll let you know as soon as possible.
Best regards,
Jon A. Bell
Autodesk Technical Support
