3DS Max 2016 + PhotoshopCC = PSD file locked ?
So, I've came across a rather stupid and annoying bug that I don't have in 3DSmax2015.
If I have a PSD field assigned as a texture to an object in the opened max scene and then open that same file in Photoshop, I can no longer save and overwrite the file. It says that the file is opened by some other application. Which is technicaly true, but I never had that problem before.
I used to edit/paint/modify PSD textures freely, save, alt+tab to max and just wait for the texture tu update. Painless, as it should be, but not anymore 😞
My collegue has the same issue. Does anyone else has this problem? Or maybe a workaround?
Thx.
lightcube
Don't use PS anymore (goodbye Adobe) but when 3ds Max 2012 (?) came out is had a bug this thread reminded me of. In that case, files created by MAXScript were locked and couldn't even be executed (in the case of a batch file) until Max closed. That was a bug that only a hotfix or service pack fixed.
Shawn Olson
Developer of Wall Worm
3ds Max 4/Gmax - 3ds Max 2027
Mudbox 2009-2022
Windows 11 x64
i9 11900K
128GB RAM
Geforce 3090
VishnuR
Yes this is a confirmed issue and already logged by several users.
No info on a fix date yet but good news it is already under investigation.
Thank you all for taking the time to report this.
10727420
Best Regards
VR
Vishnu Ramdass
maxaristov
looks like SP1 fixed that!!! yay, thanks!
Yes!
I confirm, it's fixed. Thank you.
Hello! I have same issue with SP3 while using distributed rendering with mental ray Smiley Frustrated
How to reproduce:
1. Setup distributed rendering in mental ray
2. create object and assign material with psd texture on it
3. render
4. try to make changes in psd and save it photoshop - and you will still get error.
SP3 installed on both machines.
maybe any workaround?
