Hey guys, I was recently working with exporting models to use in Unreal and both programs stopped responding so I shut both processes down using the task manager.
Now when starting 3DS Max, at the moment when I get asked to start with a template or open a file, it tries to load it but then crashes with the "application needs to close" dialog.
Help please! :C
Steve_Curley schrieb:
Try Resetting your User Settings.
This is a solution for many, many bugs/crashes... But why?
It seems that max is less robust since some releases, isn't it?
Just a idea: Max should have a backup/restore function for the user settings!
So that's easy to reset the settings to the state of e.g.: last day, last week, last month...
Please leave comments and vote here:
I'm having an empty 3D max scene with a box in it.. and when i modify it, software crashes!! ... my system is :
Mac Pro 2013
32 Gb Ram
FirePro Graphic Card
Version : 3D Max 2016 (latest SP3 installed)
Your resetting user settings solution did not work. Find all the data reports attached to this messages.
Please help.
Thanks!
Sheryl
It's a funny thing that 3dsmax, since ever, allows you to pull some very complex tricks steady as a rock, and then you just translate an object, copy a keyframe, or rotate the viewport and boom... It blows up in your face.
That's exactly what've been gewtting here: it's just impossible to copy some keyframes around.
Any setting I should look into?
i have the same problem. keep crashing or going back to the default settings where my materials and path textures will be erase. what i do is i save the settings and just load it whenever it crashed.
